[QGIS-trac] [Quantum GIS] #1160: cmake 2.6 errors
Quantum GIS qgis at qgis.org
Wed Jul 16 22:13:49 EDT 2008
   Reporter:  jctull                           |              Owner:  nobody
       Type:  bug                              |             Status:  new
   Priority:  minor: annoyance or enhancement  |          Milestone:  Version 1.0.0
  Component:  Build/Install                    |            Version:  HEAD
   Keywords:  cmake errors                     |   Platform_version:  10.5.4
   Platform:  OS X                             |           Must_fix:  No
Status_info:  0                                |
 I'm not sure if this is occurring due to changes in trunk, or if it is
 from switching to cmake 2.6. I suspect the latter. This is not affecting
 my ability to build the source, or in qgis use.
 -- Found Proj: /Library/Frameworks/PROJ.framework/unix/lib/libproj.dylib
 -- Found Sqlite3:
 /Library/Frameworks/SQLite3.framework/unix/lib/libsqlite3.dylib
 -- Found GEOS: /Library/Frameworks/GEOS.framework/unix/lib/libgeos.dylib
 -- Found GDAL:
 /Library/Frameworks/GDAL.framework/Versions/1.5/unix/lib/libgdal.dylib
 -- Found PostgreSQL: /usr/local/pgsql/lib/libpq.dylib
 -- Found Expat: /usr/lib/libexpat.dylib
 -- Using GSL from /usr/local
 -- Found GRASS: /Applications/GRASS-6.3.app/Contents/MacOS (6.3.0)
 -- Python libraries found
 -- Python bindings enabled
 CMake Warning (dev) at CMakeLists.txt:257 (ADD_DEFINITIONS):
   Policy CMP0005 is not set: Preprocessor definition values are now
 escaped
   automatically.  Run "cmake --help-policy CMP0005" for policy details.
 Use
   the cmake_policy command to set the policy and suppress this warning.
 This warning is for project developers.  Use -Wno-dev to suppress it.
 CMake Warning (dev) at CMakeLists.txt:258 (ADD_DEFINITIONS):
 escaped
 Use
 CMake Warning (dev) at CMakeLists.txt:259 (ADD_DEFINITIONS):
 escaped
 Use
 CMake Warning (dev) at src/providers/grass/CMakeLists.txt:1
 (ADD_DEFINITIONS):
 escaped
 Use
 CMake Warning (dev) at src/plugins/grass/CMakeLists.txt:4
 (ADD_DEFINITIONS):
 escaped
 Use
 CMake Warning (dev) at src/plugins/grass/CMakeLists.txt:21
 (ADD_DEFINITIONS):
 escaped
 Use
 CMake Warning (dev) at src/python/CMakeLists.txt:9 (ADD_DEFINITIONS):
 escaped
 Use
 -- Configuring done
 -- Generating done
 -- Build files have been written to: /path
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1160>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
