[QGIS-trac] [Quantum GIS] #1173: db grass modules
Quantum GIS qgis at qgis.org
Tue Jul 22 11:38:32 EDT 2008
   Reporter:  pcav                             |              Owner:  leolami
       Type:  bug                              |             Status:  new
   Priority:  minor: annoyance or enhancement  |          Milestone:  Version 1.0.0
  Component:  GRASS                            |            Version:  HEAD
   Keywords:                                   |   Platform_version:
   Platform:  All                              |           Must_fix:  No
Status_info:  0                                |
 To connect to a pg database, the user apparently must:
 - run db.connect(.schema) giving:
 Driver name (pg)
 Database name
 "host=faunalia.it,dbname=database_name" (with comma and maybe quotes)
 nameoftheschema
 - run db.login giving
 Database name
 host=faunalia.it dbname=prova_leo (with space, no comma, no quotes)
 username
 password
 This seems a bit more complicated than necessary. I suggest:
 - to have consistent syntax
 - to put each variable in a different space, separating host and db_name
 - to merge the two modules into one, so user must enter Driver name,
 host, dbname only once.
 If you look at:
 http://grass.osgeo.org/grass64/manuals/html64_user/grass-pg.html
 everything looks more simple:
 db.connect driver=pg database="host=myserver.itc.it,dbname=mydb"
 db.login user=myname [pass=secret]
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1173>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
