[QGIS-trac] Re: [Quantum GIS] #15: Consider use of the term "CRS" instead of "Projection" throughout QGIS
Quantum GIS qgis at qgis.org
Fri Jul 25 06:57:28 EDT 2008
        Reporter:  morb_au                           |         Owner:  timlinux
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 2.0.0
       Component:  Projection Support                |       Version:  HEAD
      Resolution:                                    |      Keywords:  ogc projection srs crs
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Changes (by msieczka):
  * type:  enhancement => bug
Comment:
 Replying to [comment:6 timlinux]:
 > Given the invasiveness of the changes required and that we are months
 away from 1.0.0 I'm shifting this over to 2.0.0.
 What's invasive about changing several strings in the user interface?
 Moreover this is definitely not a "feature request" but a "bug report".
 Simply, projection!=coordinate system, while QGIS uses the term
 "projection" in places where actually "coordinate system" should be used.
 Projection is only an element of a coordinate system, and only of a
 *projected* one. Unprojected CS does not even have a projection.
 Bogus terminology makes learning (and teaching) harder.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/15#comment:7>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
