[QGIS-trac] Re: [Quantum GIS] #1184: Cannot reset field settings to
<off> in layers properties
Quantum GIS
qgis at qgis.org
Fri Jul 25 18:17:54 EDT 2008
#1184: Cannot reset field settings to <off> in layers properties
Reporter: marcopx | Owner: timlinux
Type: bug | Status: assigned
Priority: major: does not work as expected | Milestone: Version 1.0.0
Component: GUI | Version: 0.11.0
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 0
Changes (by timlinux):
* status: new => assigned
* owner: nobody => timlinux
* milestone: Version 0.11.0 => Version 1.0.0
Old description:
> In the layer property window I set Rotation and Artea scale fields and
> then press OK.
> After that, when I open the property window again, and I try to set one
> of them to <off> again, I cannot do it, because I can only select one of
> the fields of the related vector layer database.
> Sample imagine attacched
> Marco
New description:
In the layer property window I set Rotation and Area scale fields and then
press OK.
After that, when I open the property window again, and I try to set one of
them to <off> again, I cannot do it, because I can only select one of the
Marco
Comment:
Note jpg images are generally smaller and attachable.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1184#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
