[QGIS-trac] [Quantum GIS] #1130: Query builder attaches sql clause to wrong entry when PostGIS table has multiple geometry columns
Quantum GIS qgis at qgis.org
Mon Jun 23 02:33:17 EDT 2008
   Reporter:  agnewtj                           |              Owner:  nobody
       Type:  defect                            |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:
  Component:  Data Provider                     |            Version:  0.10.0
   Keywords:  multiple geometry columns         |   Platform_version:
   Platform:  Debian                            |           Must_fix:  No
Status_info:  0                                 |
 We have a PostGIS table with multiple geometry tables - one polygon and
 one point.  The "Add PostGIS Table(s)" sorts the geometry columns by
 "Type".  So "Point" appears above "Polygon".
 When we double click on one of the tables and add selection criteria, the
 criteria is attached to the geometry column first in the sort sequence.
 So we have no way to add sql criteria to the "Polygon" column, since the
 criteria is always attached to "Point".
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1130>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
