[QGIS-trac] [Quantum GIS] #1072: WMS connection can't use the proxy
Quantum GIS
qgis at qgis.org
Wed May 7 08:22:56 EDT 2008
Reporter: chg | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone:
Component: WMS | Version: HEAD
Keywords: proxy | Platform_version:
Platform: SuSE | Must_fix: No
Status_info: 0 |
We have to use a proxy to connect to external WMS providers.
versions below 0.10.0 perfectly work with the proxy,
only brings following error message:
"Could not understand the response. The wms provider said:"
Terminal gives an additional error:
Warning: UNEXPECTED RESPONSE: [HTTP/1.0 403 Forbidden
Server: squid/2.6.STABLE6
Date: Mon, 05 May 2008 15:58:06 GMT
Content-Type: text/html
Content-Length: 1047
Expires: Mon, 05 May 2008 15:58:06 GMT
X-Squid-Error: ERR_ACCESS_DENIED 0
X-Cache: MISS from proxy
X-Cache-Lookup: NONE from proxy:3128
Via: 1.0 srv
Proxy-Connection: close
Settings for proxy are:
URL:
http://mapserver.jrc.it/wmsconnector/com.esri.wms.Esrimap/image2000_pan
Proxy Host: proxy
Proxy Port: 3128
Same settings did work in 0.8 and 0.9.
I can also exlude a problem with the remote server, as others also do not
work. If I omit the proxy and connect directly, it also works fine.
Used Version: 0.10.0 from openSuse repo.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1072>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
