[QGIS-trac] Re: [Quantum GIS] #1079: on the fly projections do not
work
Quantum GIS
qgis at qgis.org
Tue May 13 08:36:41 EDT 2008
#1079: on the fly projections do not work
Reporter: pcav | Owner: mhugent
Type: defect | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 0.9.2
Component: Projection Support | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 0
Changes (by msieczka):
* priority: major: does not work as expected => critical: causes crash
or data corruption
* platform: Debian => All
* cc: msieczka (added)
* milestone: => Version 0.9.2
Comment:
AFAIK, QGIS fails to recognize only SRSs which contain an *explicit k
parameter* in the SRS proj4 string (which are several hundred SRSs
anyway). It does recognize other properly though. The nature of the
problem depends on the *particular* coordinate system *and GDAL version*,
and has it's background in the fact that QGIS uses proj4 faromat-based,
string-wise SRS matching.
Example:
EPSG:2180 has a following proj4 representation in QGIS srs.db:
+proj=tmerc +lat_0=0 +lon_0=19 +k=0.999300 +x_0=500000 +y_0=-5300000
+ellps=GRS80 +units=m +no_defs
Against GDAL 1.4.4 QGIS fails to recognize this SRS because GDAL 1.4.4
inteprets EPSG:2180 as:
+proj=tmerc +lat_0=0 +lon_0=19 +k=0.9993 +x_0=500000 +y_0=-5300000
Note the difference in k above - 0.999300 against 0.9993 is the cause of
string-wise matching failure. The reason of this problem is a change in
GDAL http://trac.osgeo.org/gdal/changeset/12625.
Against GDAL > 1.4.4 QGIS fails to recognize this SRS because these GDAL
versions intepret EPSG:2180 as:
+proj=tmerc +lat_0=0 +lon_0=19 +k=0.9993000000000001 +x_0=500000
+y_0=-5300000 +ellps=GRS80 +units=m +no_defs
Again, k differ in both cases. This one is due to a bug in GDAL
https://trac.osgeo.org/gdal/ticket/2036. It is fixed in GDAL 1.6 trunk but
the fix caused side-effects, which have to be taken care of before the fix
can be backported to stable 1.5 branch.
Other SRS which do not conatin an explicit k parameter, eg. EPSG:32633,
which in proj4 representaion is:
+proj=utm +zone=33 +ellps=WGS84 +datum=WGS84 +units=m +no_defs
do not pose problems.
Back to the point - if QGIS fails to recognize the SRS of the added layer,
by default it assignes it:
+proj=longlat +ellps=WGS84 +datum=WGS84
Now, when one tries to reproject such layer on the fly, he might come to
wrong conclussion that the functionality is broken. However, the real
culprit is that the *layer's source SRS is wrong*, so the reprojection
cannot work properly. Can you Leonardo and Paolo please verify if this is
the case for you - that for Paolo the reprojection seems broken and for
Leonardo it's OK?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1079#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
