[QGIS-trac] [Quantum GIS] #1086: Don't change active layer when
adding new layer if identify tool is used
Quantum GIS
qgis at qgis.org
Tue May 13 11:09:28 EDT 2008
#1086: Don't change active layer when adding new layer if identify tool is used
Reporter: marisn | Owner: nobody
Type: enhancement | Status: new
Priority: minor: annoyance or enhancement | Milestone:
Component: GUI | Version: HEAD
Keywords: | Platform_version:
Platform: Gentoo | Must_fix: No
Status_info: 0 |
When adding new layer, QGIS automatically selects the new layer. It may
not be desirable if identify tool is used, as it works on currently
selected (active) layer.
Consider following workflow:
I have tileindex layer (shp with poligons containing path/filename to
rasters) and I'm adding raster layers based on identify tool results.
Click on tileindex_layer.shp -> Identify tool -> click on map -> read
raster name -> Add raster layer -> click on map -> OUT OF EXTENT as newly
added raster layer is now active -> start loop from beginning by selecting
tileindex_layer. If added layer list is large and I need to add lot of
layers it takes significant time to activate correct layer after every new
layer is added.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1086>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
