[QGIS-trac] Re: [Quantum GIS] #130: database default fields
Quantum GIS qgis at qgis.org
Wed May 14 16:59:49 EDT 2008
        Reporter:  cavallini at faunalia.it             |         Owner:  morb_au
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 0.9.2
       Component:  Digitising                        |       Version:  HEAD
      Resolution:  fixed                             |      Keywords:  PostGIS database digitizing
Platform_version:                                    |      Platform:  All
        Must_fix:  Yes                               |   Status_info:  0
Changes (by jef):
  * status_info:  1 => 0
Comment:
 Replying to [comment:20 mhugent]:
 > If it works or not seems to depend on the Qt version. The last try is
 r8435. It did not work for me with Qt-4.3.4 and after the commit it works
 also with this version. Reopen this patch if you still have problems after
 r8435.
 Ok, looks like I tried with Qt 4.4 on Debian unstable only.  r8435 doesn't
 work there. But given this hint, I found that <r8435 didn't work on
 Windows using Qt 4.3.4 (MSVC build).
 r8436 now works on both.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/130#comment:21>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
