[QGIS-trac] Re: [Quantum GIS] #1087: adding postgis data with
geometry field based on a domain and not a simple geometry type
Quantum GIS
qgis at qgis.org
Thu May 15 05:00:57 EDT 2008
#1087: adding postgis data with geometry field based on a domain and not a simple
geometry type
Reporter: zawardo | Owner: jef
Type: defect | Status: new
Priority: major: does not work as expected | Milestone:
Component: Data Provider | Version:
Resolution: | Keywords: postgis domain
Platform_version: 0.10 | Platform: Windows
Must_fix: No | Status_info: 1
Comment (by zawardo):
Replying to [comment:1 jef]:
> Could you provide a SQL script to create your table?
of course:
CREATE DOMAIN check_prova1
AS geometry
CONSTRAINT essere_2d CHECK ((dimension(VALUE) = 0)) CONSTRAINT
proiezione CHECK ((srid(VALUE) = 668)) CONSTRAINT essere_punto CHECK
((geometrytype(VALUE) = 'POINT'::text));
CREATE TABLE test
id integer,
the_geom check_prova1
WITH (OIDS=FALSE);
However i just noticed that manually adding che table into the geometry
_columns table, makes it visible into the qgis environment:)
It still would be fine if it was recognized even if not present in the
geometry _columns (like other tables with simple geometry type).
Thank you!
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1087#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
