[QGIS-trac] [Quantum GIS] #1102: Digitizing over an image hides
image with white mask
Quantum GIS
qgis at qgis.org
Fri May 23 06:12:24 EDT 2008
#1102: Digitizing over an image hides image with white mask
Reporter: nedhorning | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone:
Component: Digitising | Version: HEAD
Keywords: image digitiing | Platform_version:
Platform: Windows | Must_fix: No
Status_info: 0 |
There is a problem when digitizing a polygon on top of a raster image.
When digitizing a polygon layer on top of an image the area defined by the
bounding box of the polygon verticies (or any point covered by the cursor)
becomes an opaque white which hides the underlaying image. This is a
problem for us since we are trying to digitize features that can be seen
in a satellite image.
After loading the satellite image and doing an enhancement we create a new
polygon vector file and place it on top of the raster image. We then make
it editable and then start drawing a polygon. As we draw, the image area
under the bounding box of the polygon becomes white effectively creating a
mask that hides the image. The white mask disappears after the polygon is
closed. We can “erase” the white mask by refreshing the screen (using ctrl
+R) but it reappears as soon as the cursor is moved. If we move the vector
layer under the raster layer then the digitizing works fine with no white
mask but after the polygon is finished it cannot be seen since the vector
layer is under the raster layer.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1102>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
