[QGIS-trac] [Quantum GIS] #1402: Open attribute table hangs when a ShapeFile layer has usaved changes
Quantum GIS qgis at qgis.org
Fri Nov 14 04:36:46 EST 2008
   Reporter:  zachariahyoder                             |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.0.0
  Component:  Vectors                                    |            Version:  0.11.0
   Keywords:  memory leak attribute table                |   Platform_version:  Windows XP Home
   Platform:  Windows                                    |           Must_fix:  No
Status_info:  0                                          |
 To reproduce:
         Won't produce error:
                 a) Simply open the attributes table window on a ShapeFile
 layer
         Will produce error:
                 a) Change the layer to editable
                 b) Add a new point
                 c) Open the attributes table
 The memory usage will then increase about about 1G (in my test example).
 Of course this then causes the system to run slowly if you don't have that
 much memory!
 This seems very similar to #1198, however there is no PostGIS involved.
 Are they related?
 I notice there are two memory leak fixes that involved PostGIS NULL
 values, but again, this doesn't involve PostGIS.  [8217], [6391]
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1402>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
