[QGIS-trac] Re: [Quantum GIS] #1295: spatial index fails
Quantum GIS
qgis at qgis.org
Wed Oct 8 22:19:05 EDT 2008
Reporter: gespiel | Owner: jef
Type: patch | Status: new
Priority: major: does not work as expected | Milestone: Version 1.0.0
Component: Vectors | Version: HEAD
Resolution: | Keywords:
Platform_version: XP sp2 | Platform: Windows
Must_fix: Yes | Status_info: 0
Changes (by smizuno):
* status: reopened => new
* owner: nobody => jef
* type: bug => patch
Comment:
I am providing a patch that fixes this problem and also #1244 (spaces in
file names).
This uses QFileInfo::completeBaseName() to extract the file name to use as
the layer name in createSpatialIndex(). It handles both / and \. It also
deals with a potential problem with multiple dots (.) in a file name.
Identifier quoting is also applied.
I also noticed that deleteFeatures() fails in the REPACK statement as
well, although it is silent. The feature count isn't correct. So
completeBaseName() is used here, too. Note that REPACK is very particular
- it doesn't work with quotes, but it does accept spaces in the layer
name, even a leading space.
Addtionally, mEncoding->fromUnicode() was applied to the calls to OGR for
better i18n handling as has been done in some other functions.
I also used QFileInfo::completeBaseName(), replacing
QFileInfo::baseName(), in several other functions calling the layer name
in similar ways in SQL statements.
I have only tested this with GDAL/OGR 1.5.2, so I'm not sure how other
versions will work with this patch.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1295#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
