[QGIS-trac] [Quantum GIS] #1342: dxf2shp plugin does not distinguish between polygon and polyline correctly
Quantum GIS qgis at qgis.org
Thu Oct 9 19:37:03 EDT 2008
   Reporter:  brian                             |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.0.0
  Component:  Plugins                           |            Version:  HEAD
   Keywords:  dxf dxf2shp                       |   Platform_version:  Ubuntu 8.04
   Platform:  Debian                            |           Must_fix:  No
Status_info:  0                                 |
 correctly.
 In the attached example, polyline and polygons are both converted to lines
 and polygons.
 Also this applies to the text as well.
 Have tested dxf2shp with dxf files as r12 and 2000 dxf format.
 Attached is the r12 file.
 Cheers
 Brian
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1342>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
