[QGIS-trac] [Quantum GIS] #1351: WMS and DB connections should have a per connection proxy enable/disable option
Quantum GIS qgis at qgis.org
Tue Oct 14 16:16:42 EDT 2008
option
   Reporter:  neumann                           |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.0.0
  Component:  WMS                               |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  Debian                            |           Must_fix:  No
Status_info:  0                                 |
 I don't know if this is really a bug or an enhancement request. In my
 situation it is a bug - a real problem.
 I have to to use a proxy to access http resources. For external WMS I need
 to use a proxy (with user/password). However, for local WMS (for a certain
 IP range) I don't want to use the proxy. It would not even work with a
 proxy for my local WMS connections (maybe the admin did a broken proxy
 configuration?)
 My request is therefore that for each WMS and DB connection there should
 be a checkbox (use proxy or not). Default would be without proxy. We could
 still make use of the global proxy configuration as described in
 https://trac.osgeo.org/qgis/changeset/8649 - usually there is only one
 proxy, so a disable/enable per connection should work.
 Thank you for having a look at my request!
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1351>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
