[QGIS-trac] Re: [Quantum GIS] #967: CRS of a new shapefile doesn't
match CRS of the project
Quantum GIS
qgis at qgis.org
Mon Oct 27 16:58:19 EDT 2008
#967: CRS of a new shapefile doesn't match CRS of the project
Reporter: msieczka | Owner: nobody
Type: defect | Status: closed
Priority: major: does not work as expected | Milestone: Version 1.0.0
Component: Projection Support | Version: HEAD
Resolution: invalid | Keywords:
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 0
Changes (by homann):
* status: reopened => closed
* resolution: => invalid
Comment:
Replying to [comment:6 msieczka]:
> Replying to [comment:5 homann]:
> > You can select if the CRS of the new layer should be the global
default, the project CRS or if it should ask for it. You do the selection
in Settings -> Options...
> Reopening because this setting is explicitely for dealing with layers
which miss CRS data at their load time.
If you create a new layer, it does not have a CRS when you load it (after
creation). It is created on disk and then loaded.
>It is bogus that this setting impacts CRS info of layers *newly created
in >QGIS*. A newly created layer in QGIS should have the same CRS as the
>project, not as the global setting for layer's with invalid CRS data.
There is a radio button so you can mimic the behaviour you want. Do you
feel better if we add "and new layers" to that text?
>It is easy to imagine you might want to have the global CRS different
than >you project CRS. What then?
Set them differently.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/967#comment:7>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
