[QGIS-trac] Re: [Quantum GIS] #967: CRS of a new shapefile doesn't match CRS of the project
Quantum GIS qgis at qgis.org
Tue Oct 28 11:56:02 EDT 2008
        Reporter:  msieczka                          |         Owner:  nobody
            Type:  defect                            |        Status:  reopened
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.0
       Component:  Projection Support                |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  Yes                               |   Status_info:  0
Changes (by msieczka):
  * status:  closed => reopened
  * resolution:  invalid =>
Comment:
 Replying to [comment:7 homann]:
 > Replying to [comment:6 msieczka]:
 > > Replying to [comment:5 homann]:
 > > > You can select if the CRS of the new layer should be the global
 default, the project CRS or if it should ask for it. You do the selection
 in Settings -> Options...
 > > Reopening because this setting is explicitely for dealing with layers
 which miss CRS data at their load time.
 > If you create a new layer, it does not have a CRS when you load it
 (after creation). It is created on disk and then loaded.
 These are internals of how QGIS deals with creating new layers. User
 doesn't know and shouldn't. Look at it from the user's point of view
 please. If he sets a CRS for his project, he is right to expect a newly
 created layer has the same CRS as hish project, not as some global
 setting.
 > >It is bogus that this setting impacts CRS info of layers *newly created
 in >QGIS*. A newly created layer in QGIS should have the same CRS as the
 >project, not as the global setting for layer's with invalid CRS data.
 > There is a radio button so you can mimic the behaviour you want. Do you
 feel better if we add "and new layers" to that text?
 My main point is that CRS setting for a newly created layer should rather
 depend on project's CRS than a global one. And, moreover, that global
 setting is explicitely for dealing with existing layers which miss CRS. It
 is counter-intuitive and counter-productive to use this setting for 2
 different things - managing CRS of newly created layers and managing CRS
 of existing layers that miss CRS data.
 > >It is easy to imagine you might want to have the global CRS different
 than >you project CRS. What then?
 > Set them differently.
 You're missing my point or I'm putting it wrong. Again: even if I set
 global and project's CRS different, a newly created layer *still* carries
 the CRS from the global setting instead of project's CRS.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/967#comment:8>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
