[QGIS-trac] Re: [Quantum GIS] #1339: Can't set projection to WGS84
UTM Zone 15N
Quantum GIS
qgis at qgis.org
Wed Oct 29 07:01:58 EDT 2008
#1339: Can't set projection to WGS84 UTM Zone 15N
Reporter: vedgewater | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.0.0
Component: Projection Support | Version: 0.11.0
Resolution: | Keywords: UTM SRSID
Platform_version: | Platform: Gentoo
Must_fix: No | Status_info: 0
Comment (by fpacheco):
Vince,
If you just want to get the layer by name and then take for example the
srsid believe that this code would be sufficient:
def getVectorLayerByName(myName):
mc = iface.getMapCanvas()
nLayers = mc.layerCount()
for l in range(nLayers):
layer = mc.getZpos(l)
if str(layer.name()) == str(myName):
return layer
regionLayer = getVectorLayerByName("boundaryPolygons_004")
regionLayer.srs().srsid()
Please, try it and tell me the results. Regards, Fernando.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1339#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
