[QGIS-trac] [Quantum GIS] #1610: Update Preview in map composer
doesn't work
Quantum GIS
qgis at qgis.org
Wed Apr 1 05:00:39 EDT 2009
#1610: Update Preview in map composer doesn't work
Reporter: bjpfei | Owner: mhugent
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.0.2
Component: Printing | Version: HEAD
Keywords: | Platform_version:
Platform: RedHat | Must_fix: Yes
Status_info: 0 |
It seems that the update preview button in the map composer doesn't work
correct anymore.
Try this:[[BR]]
1.) open the map composer[[BR]]
2.) add a new map[[BR]]
3.) Select Cache in the preview box. The preview in the map is correct so
far.[[BR]]
4.) Change the map in the main window eg change the zoom level or the
extent[[BR]]
5.) Now try to update the preview in the map composer by pressing the
update preview button. Nothing happens.[[BR]]
Qgis version is 1.0.2 code revision 10413.[[BR]]
It also happens with version 1.1.0 and code revision 10441[[BR]]
[[BR]]
Thanks
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1610>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
