[QGIS-trac] [Quantum GIS] #1621: Compilation process failed when Spatialite is enabled
Quantum GIS qgis at qgis.org
Fri Apr 3 13:54:57 EDT 2009
   Reporter:  hdus                              |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.1.0
  Component:  Build/Install                     |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  Linux                             |           Must_fix:  No
Status_info:  0                                 |
 The compilation process failed, when spatialite is enabled.
 The following error message appears:
 In Datei, eingefügt von /usr/local/src/qgis/qgis/src/app/qgisapp.cpp:179:
 /usr/local/src/qgis/qgis/src/app/qgsspatialitesourceselect.h:27:32: Error:
 spatialite/sqlite3.h: No such file or directory
 Sqlite and Spatialite are defined correct with ccmake. The failure appears
 with {{{WITH_INTERNAL_SQLITE3}}} on or off.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1621>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
