[QGIS-trac] [Quantum GIS] #1634: snapping tolerance in pixels does not work if on-the-fly reprojection is enabled
Quantum GIS qgis at qgis.org
Sun Apr 5 14:58:49 EDT 2009
enabled
   Reporter:  mhugent                           |              Owner:  wonder
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:
  Component:  Digitising                        |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
 1. load a layer in a meter coordinates system
 2. set snapping tolerance in pixel (e.g. 20 pixels)
 3. edit, everything works fine
 4. reproject the layer to WGS84, decimal degrees
 5. edit again. The snapping distance of 20 pixels does not apply to the
 layer any more
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1634>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
