[QGIS-trac] Re: [Quantum GIS] #1629: replace v.buffer with v.buffer2 for GRASS 6.4
Quantum GIS qgis at qgis.org
Thu Apr 23 03:52:39 EDT 2009
        Reporter:  pcav                              |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:
       Component:  GRASS                             |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Changes (by neteler):
 * cc: neteler (added)
Comment:
 I cannot reproduce this:
 GRASS 6.4.0svn (spearfish60):~ > v.buffer --interface-description
 <!DOCTYPE task SYSTEM "grass-interface.dtd">
 <task name="v.buffer">
         <description>
                 Creates a buffer around features of given type (areas must
 contain centroid).
         </description>
         <keywords>
                 vector, buffer
         </keywords>
 The new code is obviously named "v.buffer" as before:
 GRASS 6.4.0svn (spearfish60):~/grass64 > head vector/v.buffer2/Makefile
 MODULE_TOPDIR = ../..
 PGM = v.buffer
 The GRASS 6 production line should maintain full compatibility even if a
 module is rewritten from scratch as in the case of v.buffer.
 GRASS 6.4.0svn (spearfish60):~/grass64 > v.buffer help
 Description:
  Creates a buffer around features of given type (areas must contain
 centroid).
 Keywords:
  vector, buffer
 Usage:
  v.buffer [-sc] input=name output=name [type=string[,string,...]]
    [layer=value] [distance=value] [minordistance=value] [angle=value]
    [bufcolumn=name] [scale=value] [tolerance=value] [--overwrite]
    [--verbose] [--quiet]
 Ha, I see the problem:
 # GRASS 6.3,
 http://grass.osgeo.org/grass63/manuals/html63_user/v.buffer.html:
 buffer=float
     Buffer distance in map units
 # GRASS 6.4,
 http://grass.osgeo.org/grass64/manuals/html64_user/v.buffer.html:
 distance=float
     Buffer distance along major axis in map units
 This is bad and needs to be fixed in GRASS unless QGIS can update "buffer"
 to "distance" in the XML file.
 Markus
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1629#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
