[QGIS-trac] Re: [Quantum GIS] #1629: parameter name changed in v.buffer from GRASS 6.3 to GRASS 6.4
Quantum GIS qgis at qgis.org
Thu Apr 23 08:12:27 EDT 2009
        Reporter:  pcav                              |         Owner:  nobody
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:
       Component:  GRASS                             |       Version:  HEAD
      Resolution:  fixed                             |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Comment (by hamish):
 Markus:
 > unless QGIS can update "buffer" to "distance" in the XML file.
 Even though the old name now works again, the XML file should be updated
 for forward compatibility with GRASS 7, when the old name will be removed
 again. (currently both names for it work)
 Hamish
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1629#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
