[QGIS-trac] Re: [Quantum GIS] #1629: parameter name changed in
v.buffer and r.surf.fractal from GRASS 6.3 to GRASS 6.4
Quantum GIS
qgis at qgis.org
Thu Apr 23 09:14:13 EDT 2009
#1629: parameter name changed in v.buffer and r.surf.fractal from GRASS 6.3 to
GRASS 6.4
Reporter: pcav | Owner: nobody
Type: bug | Status: reopened
Priority: major: does not work as expected | Milestone:
Component: GRASS | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Comment (by hamish):
Replying to [comment:8 pcav]:
> Same thing happens for r.surf.fractal (option d=float has been
> changed in option dimension=float), so it does not work with
> grass64
that one should not matter, the parser will accept shorter names.
See http://grass.osgeo.org/wiki/Module_command_line_parser
> I reopen the ticket, to remember changing the option when
> grass63 will be deprecated, and no longer widely available.
maybe better just to leave the XML file as it is and close the ticket. A
stable GRASS 7 release may be a long time away.
Hamish
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1629#comment:9>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
