[QGIS-trac] Re: [Quantum GIS] #1617: update of raster layers in GRASS modules
Quantum GIS qgis at qgis.org
Tue Apr 28 03:53:22 EDT 2009
        Reporter:  pcav                              |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.3
       Component:  GRASS                             |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  Debian
        Must_fix:  No                                |   Status_info:  0
Comment (by rblazek):
 (Un)fortunately this inconsistency comes from GRASS. If a module has
 defined output option in GRASS correctly the button 'View output' is
 added. You can check this if you run the command with --interface-
 description. The output option should have <gisprompt age="new"
 element="cell" prompt="raster" /> tag.
 r.surf.fractal did not have the output defined correctly, which was
 however fixed already:
 http://trac.osgeo.org/grass/changeset/34761
 Radim
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1617#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
