[QGIS-trac] Re: [Quantum GIS] #1663: QGIS uses wrong GRASS library.
Quantum GIS qgis at qgis.org
Wed Apr 29 23:13:39 EDT 2009
        Reporter:  cgsbob                                     |         Owner:  nobody
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:
       Component:  GRASS                                      |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Debian
        Must_fix:  No                                         |   Status_info:  0
Comment (by cgsbob):
 Replying to [comment:1 jef]:
 > setup LD_LIBRARY_PATH to point to the correct grass library path
 (probably /usr/local/grass-6.5.svn/lib in your case).
 I put both /usr/local/grass-6.5.svn/lib and /usr/local/grass-7.0.svn/lib
 in LD_LIBRARY_PATH.  I reversed those two paths and now qgis starts
 without crashing.  So it seems that qgis loads the first grass
 library...even if the library is not under the GRASS_PREFIX directory?
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1663#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
