[QGIS-trac] [Quantum GIS] #1665: Use of relative paths for SVG symbols in QGIS project file
Quantum GIS qgis at qgis.org
Thu Apr 30 04:25:49 EDT 2009
   Reporter:  neumann                          |              Owner:  nobody
       Type:  bug                              |             Status:  new
   Priority:  minor: annoyance or enhancement  |          Milestone:  Version 1.2.0
  Component:  Project Loading / Saving         |            Version:  HEAD
   Keywords:                                   |   Platform_version:
   Platform:  All                              |           Must_fix:  No
Status_info:  0                                |
 Currently, QGIS uses absolute paths in project files. This is a problem
 when moving projects around, especially when using it in multiple
 operating systems.
 QGIS should use relative paths (relative to the qgis/share/svg directory),
 which is different on every platform.
 as an example:
 svg:/usr/local/share/qgis/svg/abwasser/Baujahrwechsel.svg
 should be changed to
 svg:abwasser/Baujahrwechsel.svg
 QGIS should also automagically replace forward with backward slashes when
 it opens on the windows platform. It would be useful to use the forward
 slashes notation in the project file for all platforms to be consistent.
 This is also the convention with URLs.
 Thanks for looking at this problem.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1665>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
