[QGIS-trac] Re: [Quantum GIS] #1716: improvements to ZoomLast,
ZoomNext tools (extent history)
Quantum GIS
qgis at qgis.org
Mon Aug 3 21:31:12 EDT 2009
#1716: improvements to ZoomLast, ZoomNext tools (extent history)
Reporter: smizuno | Owner: mhugent
Type: patch | Status: new
Priority: minor: annoyance | Milestone: Version 1.2.0
Component: GUI | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Comment (by smizuno):
Replying to [comment:3 lutra]:
> I tried your patch, I applied it and qgis compiled fine and worked the
first time, then it started to giving me segmentation faults when
launching the program.
I have most recently applied the patch to r11179 and has been working OK
on my Windows system. It has also worked on a Linux system, but I haven't
tested it recently, due to problems with that system. Were you applying
the patch to a more recent version? I will check further.
> it is supposed to see different zoomnext soomlast buttons if there is an
extent to zoom to?
The buttons should be enabled when there is an extent in the queue to use
whichever direction you are navigating. The buttons are disabled (grayed)
when you reach either end of the extent queue. There aren't different
icons, they are just colored or grayed.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1716#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
