[QGIS-trac] Re: [Quantum GIS] #1716: improvements to ZoomLast,
ZoomNext tools (extent history)
Quantum GIS
qgis at qgis.org
Tue Aug 4 22:04:08 EDT 2009
#1716: improvements to ZoomLast, ZoomNext tools (extent history)
Reporter: smizuno | Owner: mhugent
Type: patch | Status: new
Priority: minor: annoyance | Milestone: Version 1.2.0
Component: GUI | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Comment (by smizuno):
Replying to [comment:5 lutra]:
> As a fact I applied the patch to a more recent version (I don't remember
exactly, I compile from source very day), but I had to make some changes
manually as since you posted the patch the code has changed, so it is
possible that I made something wrong (I also didn't see any changes in the
zoom buttons).
Upon applying the patch to r11258 I found that one part for QgisApp
patches the wrong place which caused some null pointers that were used
before being initialized. The part that was affected was where signals are
connected. I can't figure out why the patch is applied rather than failing
to patch.
I have created a revised patch file.
The zoomlast button will be enabled and the zoomnext button is disabled
when QGIS is first started. If you load a project both buttons will be
disabled until some zooming or panning is done. Then you can navigate the
history of the zoom/pan with the buttons.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1716#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
