[QGIS-trac] Re: [Quantum GIS] #1701: copy and paste of objects
should take care of KBS
Quantum GIS
qgis at qgis.org
Mon Aug 10 11:32:18 EDT 2009
#1701: copy and paste of objects should take care of KBS
Reporter: mlechner | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.2.0
Component: Projection Support | Version: HEAD
Resolution: | Keywords: copy/paste, projections
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 1
Changes (by lutra):
* keywords: copy paste KBS => copy/paste, projections
* type: enhancement => bug
Comment:
For what I see now on the user manual (tip 21 on page 58 of the qgis 1.1
manual) it seems that when pasting a feature from a layer with a different
projection, qgis should reproject it (but with an advice of possibly have
the geometry of the pasted layer changed), so the bug should be confirmed.
Please check it and correct me if I'm wrong, because it seems strange to
me that a documented feature is not working the right way.
[[BR]]
[[BR]]
From the manual
''CONGRUENCY OF PASTED FEATURES
If your source and destination layers use the same projection, then the
pasted features will have geometry identical to the source layer. However
if the destination layer is a different projection then QGIS cannot
guarantee the geometry is identical. This is simply because there are
small rounding-off errors involved when converting between projections.''
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1701#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
