[QGIS-trac] Re: [Quantum GIS] #1642: v.to.db GRASS tool interface problem
Quantum GIS qgis at qgis.org
Tue Aug 11 08:32:53 EDT 2009
        Reporter:  mvizzari                          |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.3
       Component:  GRASS                             |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Comment (by pcav):
 It does show the column list, but it does not update it if the module is
 already opened when a layer is loaded. To check, close the module, load a
 layer and see if you can see the list of columns.
 However, I found another problem: the module does not work if you want to
 update several columns, as it happens for X.Y coordinates (this option
 requires two columns, but the module can only add one):
 v.to.db map=boundary_county at user1 layer=1 option=coor units=meters
 columns=Z_MEAN
 This option requires at least two columns
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1642#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
