[QGIS-trac] Re: [Quantum GIS] #1079: on the fly projections do not
work
Quantum GIS
qgis at qgis.org
Thu Aug 13 04:35:46 EDT 2009
#1079: on the fly projections do not work
Reporter: pcav | Owner: timlinux
Type: defect | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.2.0
Component: Projection Support | Version: HEAD
Resolution: | Keywords: srs.db datum
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 1
Comment (by lutra):
Replying to [comment:22 homann]:
> What is the status of this bug? Do we need to fix the CRS recognition
logic yet?
[[BR]]
I don't know if someone else noticed, but the problems described in this
ticket (together with #418) probably makes that the projections of the
vectors in the qgis sample dataset are not recognized by qgis itself. This
is very puzzling for new users.
I noticed also the following:
*) sample data is declared to be in epsg 2964
http://www.qgis.org/en/download/sample-data.html
but the string I see in the "general" tab after loading a vector, is
different from the 2964 one in the qgis internal db.
*) When I try to select 2964 from the list of available projections, it
doesn't changes and remain with the original string. This doesn't happens
if I choose any other projection from the available list.
*) If I create a custom CRS with the string I see in the "general" tab,
then it works and is recognized, but I have to take care to strip the
blank space a the end of it, otherwise doesn't works.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1079#comment:26>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
