[QGIS-trac] Re: [Quantum GIS] #1875: A few problems with crs definitions with TOWGS parameters
Quantum GIS qgis at qgis.org
Wed Aug 19 11:57:23 EDT 2009
        Reporter:  lutra                                      |         Owner:  homann
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.2.0
       Component:  Projection Support                         |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:
Platform_version:                                             |      Platform:  All
        Must_fix:  No                                         |   Status_info:  0
Comment (by warmerdam):
 Reviewing the ogr_srs_proj4.cpp code the +datum=nzgd49 is only generated
 when exporting to PROJ.4 if a 6272 datum authority code is present in the
 WKT.  There is no attempt to recognize this datum by datum name.
 If you wish to take exception to this you might want to file a ticket in
 the GDAL/OGR trac.  I'm willing to contemplate improved logic.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1875#comment:44>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
