[QGIS-trac] Re: [Quantum GIS] #1889: wrong/missing crs parameters
for CH1903 / LV03 (epsg:21781) in prj-file
Quantum GIS
qgis at qgis.org
Wed Aug 26 04:19:43 EDT 2009
#1889: wrong/missing crs parameters for CH1903 / LV03 (epsg:21781) in prj-file
Reporter: zicke | Owner: nobody
Type: bug | Status: closed
Priority: major: does not work as expected | Milestone: Version 1.3.0
Component: Projection Support | Version: HEAD
Resolution: worksforme | Keywords:
Platform_version: | Platform: Linux
Must_fix: No | Status_info: 0
Changes (by homann):
* status: new => closed
* resolution: => worksforme
Comment:
What version of QGIS did you use? This was hopefully fixed two weeks ago,
and now the result is:
PROJCS["unnamed",GEOGCS["Bessel
1841",DATUM["unknown",SPHEROID["bessel",6377397.155,299.1528128],TOWGS84[674.374,15.056,405.346,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Hotine_Oblique_Mercator"],PARAMETER["latitude_of_center",46.95240555555556],PARAMETER["longitude_of_center",7.439583333333333],PARAMETER["azimuth",90],PARAMETER["rectified_grid_angle",90],PARAMETER["scale_factor",1],PARAMETER["false_easting",600000],PARAMETER["false_northing",200000],UNIT["Meter",1]]
The library we use (GDAL/OGR) does not know about many datums, so it
cannot write in clear text the datum name. The TOWGS84 parameters are
there, though.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1889#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
