[QGIS-trac] Re: [Quantum GIS] #1802: problem when using a
geographic CRS after changing the central meridian
Quantum GIS
qgis at qgis.org
Wed Aug 26 05:15:56 EDT 2009
#1802: problem when using a geographic CRS after changing the central meridian
Reporter: lutra | Owner: nobody
Type: bug | Status: closed
Priority: major: does not work as expected | Milestone: Version 1.3.0
Component: Projection Support | Version: HEAD
Resolution: duplicate | Keywords:
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 0
Changes (by homann):
* status: new => closed
* resolution: => duplicate
Comment:
This is a duplicate of #597. As you can see the American continent wraps
around, which means the polygons should really by split.
Basically, you can't set up your projections such that geometries must be
split.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1802#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
