[QGIS-trac] Re: [Quantum GIS] #1905: Relative/Absolute paths are not
recalculated on project save
Quantum GIS
qgis at qgis.org
Mon Aug 31 18:28:51 EDT 2009
#1905: Relative/Absolute paths are not recalculated on project save
Reporter: gislab | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.3.0
Component: Project Loading / Saving | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Comment (by lutra):
I tested the behaviour also under windows (qgis-dev from osgeo4w) and the
result seems the same to me. When I save a project (after clearing the
checkbox to save relative paths) the path to a layer in the .qgs file is
relative if the project file resides in a folder that stays at the same
level or above the one of the layer. If the project file resides in a
folder below the one of the layer, then the path is absolute.
So, if you have layers coming from different folders, and depending where
you save the project, you may have correct relative paths, incorrect
absolute ones and even a project file with a mix of relative and absolute
paths.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1905#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
