[QGIS-trac] [Quantum GIS] #1525: graticule creator: don't use
reserved SQL words as column names
Quantum GIS
qgis at qgis.org
Tue Feb 3 08:38:30 EST 2009
#1525: graticule creator: don't use reserved SQL words as column names
Reporter: neteler | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.0.1
Component: Vectors | Version: 1.0.0
Keywords: graticule | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
The changeset r8183 introduced the use of a reserved SQL word ('Column')
as column name which renders the import of a graticule (SHAPE) file rather
hard:
GRASS 6.5.svn (latlong_tbe_climate):~ > v.in.ogr italy_white_box_LL.shp
out=italy_white_box_LL
Projection of input dataset and current location appear to match
Layer: italy_white_box_LL
DBMI-DBF driver error:
SQL parser error: syntax error, unexpected COLUMN, expecting NAME
processing 'Column'
in statement:
create table italy_white_box_LL (cat integer, LabelX double precision,
LabelY double precision, LblOffsetX integer, LblOffsetY integer, Label
varchar ( 80 ), Row varchar ( 80 ), Column varchar ( 80 ), RowCol varchar
( 80 ))
Error in db_execute_immediate()
ERROR: Unable to create table: 'create table italy_white_box_LL (cat
integer, LabelX double precision, LabelY double precision,
LblOffsetX integer, LblOffsetY integer, Label varchar ( 80 ), Row
varchar ( 80 ), Column varchar ( 80 ), RowCol varchar ( 80 ))'
Ref: http://developer.mimer.com/validator/sql-reserved-words.tml
Please select a different column name - suggestion: e.g., add a preceding
"g" for graticule.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1525>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
