[QGIS-trac] [Quantum GIS] #1534: Cannot Select Custom Projection
(CRS)
Quantum GIS
qgis at qgis.org
Sun Feb 8 16:57:41 EST 2009
#1534: Cannot Select Custom Projection (CRS)
Reporter: Stephan66 | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.0.1
Component: Projection Support | Version: 1.0.0
Keywords: | Platform_version: 11.1
Platform: SuSE | Must_fix: Yes
Status_info: 0 |
1: I defined a Custom Coordinate Reference System (similar to Amersfoort /
RD new) through the menu Settings | Custom CRS:
+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.999908
+x_0=155000 +y_0=463000 +ellps=bessel +units=m
+towgs84=565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.8703473836068,4.0812
+no_defs
And named it "Rijksdriehoekstelsel in m";
After hitting the "Save" button a text in the dialog says: "1 of 1".
Closing Qgis and re-opening it preserves this custom definition. (
Usability-note: the meaning of some of these icon-buttons is not obvious)
2: Testing this CRS in the same dialog works fine (Usability-note: having
to re-enter it in the field "parameters" before testing is not obvious)
3: I have added two vector layers: one from a GPX file (CRS=WGS 84). One
from a Shape-file (without .PRJ) from a Dutch government site. I need the
custom CRS for this layer and as target for the OTF Projection.
4. Entering the CRS tab in "Settings | Project properties" or right-
clicking a layer (selecting Properties | General | Change CRS) produces a
list of available CRS definitions. I cannot see or select my Custom CRS. I
guess it should be listed under "User defined coordinate systems", but
it's not (no expansion "+"-sign visible either). Searching the list yields
nothing.
Problem observed with:
QGIS version 1.0.0 (openSuSE 10.3, using Qt 4.3.1)
QGIS version 1.0.0 (openSuSE 11.1, using Qt 4.4.0)
both versions obtained from
http://download.opensuse.org/repositories/Application:/Geo/
QGIS version 1.0.0-preview 2 (Windows, running in wine under openSuSE
11.1, obtained from your website)
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1534>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
