[QGIS-trac] Re: [Quantum GIS] #1537: Units unknown in GRASS mapset
creation for EPSG 26745
Quantum GIS
qgis at qgis.org
Fri Feb 13 11:56:11 EST 2009
#1537: Units unknown in GRASS mapset creation for EPSG 26745
Reporter: jctull | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.0.1
Component: GRASS | Version: HEAD
Resolution: | Keywords: grass mapset creation epsg:26745 units unknown
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Comment (by neteler):
Using GRASS directly, it works:
GRASS 6.5.svn (nc_spm_07):~ > g.proj -c epsg=26745 loc=dd
Location dd created!
exit
grass65 ~/grassdata/dd/PERMANENT/
GRASS 6.5.svn (dd):~ > g.proj -w
PROJCS["Lambert Conformal Conic",
GEOGCS["clark66",
DATUM["North_American_Datum_1927",
SPHEROID["Clarke_1866",6378206.4,294.9786982]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",35.46666666666667],
PARAMETER["standard_parallel_2",34.03333333333333],
PARAMETER["latitude_of_origin",33.5],
PARAMETER["central_meridian",-118],
PARAMETER["false_easting",2000000],
PARAMETER["false_northing",0],
UNIT["US survey foot",0.3048006096012192]]
GRASS 6.5.svn (dd):~ > g.proj -p
-PROJ_INFO-------------------------------------------------
name : Lambert Conformal Conic
proj : lcc
datum : nad27
ellps : clark66
lat_1 : 35.46666666666667
lat_2 : 34.03333333333333
lat_0 : 33.5
lon_0 : -118
x_0 : 609601.2192024384
y_0 : 0
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : US survey foot
units : US survey feet
meters : 0.3048006096012192
I suspect an GDAL/OGR issue (GRASS is calling those functions, see
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/lib/proj/convert.c
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1537#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
