[QGIS-trac] Re: [Quantum GIS] #1537: Units unknown in GRASS mapset
creation for EPSG 26745
Quantum GIS
qgis at qgis.org
Fri Feb 13 15:42:56 EST 2009
#1537: Units unknown in GRASS mapset creation for EPSG 26745
Reporter: jctull | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.0.1
Component: GRASS | Version: 1.0.0
Resolution: | Keywords: grass mapset creation epsg:26745 units unknown
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Changes (by neteler):
* version: HEAD => 1.0.0
Comment:
Using QGIS Version_1_0 branch, I can replicate the problem:
Plugins -> GRASS -> New Mapset -> Next -> Create New location -> Next ->
Projection -> EPSG-ID 26745 -> Search -> Next and so on...
Opening the created Location in GRASS shows:
GRASS 6.5.svn (testloc):~ > g.proj -w
PROJCS["Lambert Conformal Conic",
GEOGCS["clark66",
DATUM["North_American_Datum_1927",
SPHEROID["Clarke_1866",6378206.4,294.9786982]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",35.46666666666667],
PARAMETER["standard_parallel_2",34.03333333333333],
PARAMETER["latitude_of_origin",33.5],
PARAMETER["central_meridian",-118],
PARAMETER["false_easting",2000000],
PARAMETER["false_northing",0],
UNIT["unknown",0.3048006096012192]] <<-- !
The desired Unit should be "US survey foot" which is
grep 'US survey foot' *
unit_of_measure.csv:9003,US survey foot,length,9001,12,39.37,Used in
USA.,EPSG,EPSG,2000-05-07,99.99,0
Since it works in GRASS, it seems to be a lookup problem in QGIS. I don't
know how the EPSG lookup mechanism in QGIS works, so I dunno how to debug
this further.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1537#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
