[QGIS-trac] Re: [Quantum GIS] #1534: Cannot Select Custom
Projection (CRS)
Quantum GIS
qgis at qgis.org
Mon Feb 16 08:38:05 EST 2009
#1534: Cannot Select Custom Projection (CRS)
Reporter: Stephan66 | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.0.2
Component: Projection Support | Version: 1.0.0
Resolution: | Keywords:
Platform_version: 11.1 | Platform: SuSE
Must_fix: Yes | Status_info: 0
Comment (by Stephan66):
This comment on the subject was posted by user Ines Schwarzbach on the
Qgis forum:
The solution with the Stereographic projection
+proj=stere
works fine at me, too.
But I think there is a difference between Oblique stereographic projection
+proj=sterea and
a "simple" Streographic projection with +proj=stere.
I've tested this parameters with the proj4 command cs2cs and there are the
following results:
cs2cs +proj=sterea +lat_0=34.2 +lon_0=39.15 +k=0.999534
+x_0=281796.701 +y_0=28040.358 +a=6378249.2 +b=6356515 +units=m +no_defs
+to +proj=latlong +datum=WGS84
9657.511 10507.357
36d12'10.22"E 34d0'23.232"N 0.000
cs2cs +proj=stere +lat_0=34.2 +lon_0=39.15 +k=0.999534 +x_0=281796.701
9657.511 10507.357
36d12'10.1"E 34d0'23.823"N 0.000
The differences are quite large. So the problem still exists.
Ines
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1534#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
