[QGIS-trac] Re: [Quantum GIS] #1545: Qgis should cope with table
aliases in view definitions
Quantum GIS
qgis at qgis.org
Fri Feb 20 01:36:50 EST 2009
#1545: Qgis should cope with table aliases in view definitions
Reporter: pcreso | Owner: nobody
Type: enhancement | Status: new
Priority: major: does not work as expected | Milestone:
Component: Data Provider | Version: HEAD
Resolution: | Keywords: Postgis view unique
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Changes (by gjm):
* platform: SuSE => All
* version: 0.11.0 => HEAD
* type: bug => enhancement
* summary: Qgis erroneously fails to find a unique key in a PostGIS view
=> Qgis should cope with table aliases in view
definitions
Comment:
After some debugging with Brent (aka pcreso), we found the problem was
that qgis is unable to deal with columns in a view where the view
definition contained table aliases and the view column was renamed using
AS. The symptoms weren't a good indication of the underlying problem.
For example, in this view:
{{{create view view1 as select o.id AS id_1 from table1 o;}}}
qgis won't see the id column. If the view was:
{{{create view view1 as select table1.id AS id_1 from table1;}}}
qgis would work fine.
This is a deficiency with how qgis parses the view definitions.
So, to turn this ticket around, I've changed it to an enhancement that
qgis parse table aliases. Adding in the patch in #1535 would also provide
for a way around qgis not correctly parsing other details in view
definitions.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1545#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
