[QGIS-trac] [Quantum GIS] #1558: WGS84 conversion to EPSG:27700 in error by greater than 100 metres
Quantum GIS qgis at qgis.org
Fri Feb 20 15:06:16 EST 2009
   Reporter:  nhopton                           |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:
  Component:  Projection Support                |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  Windows                           |           Must_fix:  No
Status_info:  0                                 |
 OSGB (EPSG: 27700) CRS Problem. Version 1.0.0 (II)
 When reprojecting a WGS84 shape file to EPSG:27700 (Ordnance Survey of
 Great Britain) on the fly in QGIS I noticed errors of around 125 metres in
 the conversion. This is quite serious for users in the UK. Error in
 conversion of this magnitude are usually the result of the conversion not
 taking into account the fact the WGS84 datum and the OSGB36 datum are not
 one and the same thing (but the conversion does use the +datum=osgb36
 parameter, I don't understand).
 For the time being I've defined my own OS CRS using the following
 parameters:
 +proj=tmerc +lat_0=49 +lon_0=-2 +k=0.999601 +x_0=400000 +y_0=-100000
 +ellps=airy
 +towgs84=446.448,-125.157,542.060,0.1502,0.2470,0.8421,-20.4894 +units=m
 +no_defs no_defs <>
 Which converts from WGS84 to EPSG:27700 good to a metre or so. I've had
 this problem with other software that uses Proj.4.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1558>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
