[QGIS-trac] [Quantum GIS] #1479: map composer: adding scalebar when
view is added crashes qgis
Quantum GIS
qgis at qgis.org
Wed Jan 7 08:29:49 EST 2009
#1479: map composer: adding scalebar when view is added crashes qgis
Reporter: alicebtoklas | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone:
Component: Build/Install | Version: 1.0.0
Keywords: | Platform_version:
Platform: Debian | Must_fix: No
Status_info: 0 |
In the map composer, when the map is already added, adding the scalebar
crashes QGIS. The following error message is given:
Fatal: ASSERT failure in QList<T>::at: "index out of range", file
/usr/include/qt4/QtCore/qlist.h, line 391
Abandon
Adding the scalebar first and then the map works, but then QGIS also
crashes when trying to modify the scalebar.
(on ubuntu 8.04)
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1479>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
