[QGIS-trac] Re: [Quantum GIS] #1485: Running on Intrepid 64, version 1.0.0 (stable), crashes when playing with symbology
Quantum GIS qgis at qgis.org
Fri Jan 16 21:31:50 EST 2009
symbology
        Reporter:  FiReSTaRT                                  |         Owner:  nobody
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.0.1
       Component:  Symbology                                  |       Version:  HEAD
      Resolution:                                             |      Keywords:  symbology
Platform_version:  Ubuntu Intrepid 8.10                       |      Platform:  Linux
        Must_fix:  No                                         |   Status_info:  0
Comment (by wildintellect):
 I can verify this issue on Intrepid 32bit, and believe it revolves around
 dbf field types.
 When you try to run the classify function on a column N,19 qgis crashes
 columns of type N,9 works fine. (As reported via OpenOffice)
 Looking at
 [http://www.clicketyclick.dk/databases/xbase/format/data_types.html dbf
 documentation] N field should be less than 18 chars, which makes me think
 the fields are being misidentified and should be floating point, F.
 Applies to polygon layer symbology
 * Graduated Symbol or
 * continuous on a polygon
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1485#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
