[QGIS-trac] Re: [Quantum GIS] #1427: GRASS vectors support: memory
leak?
Quantum GIS
qgis at qgis.org
Mon Jan 19 17:10:53 EST 2009
#1427: GRASS vectors support: memory leak?
Reporter: msieczka | Owner: nobody
Type: bug | Status: reopened
Priority: critical: causes crash or data corruption | Milestone: Version 1.0.1
Component: GRASS | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: Debian
Must_fix: Yes | Status_info: 0
Changes (by msieczka):
* status: closed => reopened
* resolution: worksforme =>
Comment:
Replying to [comment:6 pcav]:
> Please check if this still applies - I tested extensively, without
problems.
> If it still holds true, please reopen the ticket.
Replying to [comment:3 pcav]:
> Tested with spearfish, and it works. Please check whether it is a local
problem on your
> computer and reopen it if necessary.
The bug is still present. I don't see how it could be a problem with my
machine. Can you elaborate?
The same dat as a GRASS vector map make QGIS allocate memory but not free
it - I can make QGIS crash this way due to depleting all RAM and swap
within minutes, only panning and zooming around. However, the same data as
a Shapefile don't pose memory allocation problems to QGIS.
QGIS trunk r91492, GDAL 1.6+SVN r87108, GRASS 6.5 r73468.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1427#comment:7>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
