[QGIS-trac] Re: [Quantum GIS] #1391: Unique Value classification:
problems with symbology of features
Quantum GIS
qgis at qgis.org
Fri Jul 10 11:09:22 EDT 2009
#1391: Unique Value classification: problems with symbology of features
Reporter: pls | Owner: nobody
Type: bug | Status: closed
Priority: critical: causes crash or data corruption | Milestone: Version 1.2.0
Component: Symbology | Version: HEAD
Resolution: worksforme | Keywords:
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 0
Changes (by jef):
* status: new => closed
* resolution: => worksforme
Comment:
Replying to [ticket:1391 pls]:
> In the vector layer properties dialog it is possible to change the
values of the attributes I chose for a Unique Value classification; this
is particularly useful if you have non-meaningful values names in the
attribute field used for the classification. The problem is, when the
modification is applied to the layer, all the points pertaining to the
modified value's class disappear from the layer.
You probably edited the attribute values instead of adding a description
on the right.
Changing the value means that you want features with the value you enter
in the classification field to look like the features with the original
value looked like. Moreover you don't loose the class for the original
value and therefore those features won't be rendered anymore.
Editing the is meant to add classes that do not yet have features for.
BTW r10986 adds a default class that renders classless features.
I'm not sure if I understood your problem correctly. Feel free to reopen,
if I didn't.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1391#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
