[QGIS-trac] Re: [Quantum GIS] #1391: Unique Value classification:
problems with symbology of features
Quantum GIS
qgis at qgis.org
Fri Jul 10 11:34:06 EDT 2009
#1391: Unique Value classification: problems with symbology of features
Reporter: pls | Owner: nobody
Type: bug | Status: closed
Priority: critical: causes crash or data corruption | Milestone: Version 1.2.0
Component: Symbology | Version: HEAD
Resolution: worksforme | Keywords:
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 0
Comment (by lutra):
Replying to [comment:2 jef]:
> You probably edited the attribute values instead of adding a description
on the right.
> Changing the value means that you want features with the value you enter
in the classification field to look like the features with the original
value looked like. Moreover you don't loose the class for the original
value and therefore those features won't be rendered anymore.
> Editing the is meant to add classes that do not yet have features for.
> BTW r10986 adds a default class that renders classless features.
> I'm not sure if I understood your problem correctly. Feel free to
reopen, if I didn't.
Ok I got it.
But then I have a question.
Have a look to the attached image, it is right what I'm seeing? I mean, is
right to see repeated twice in the legend the value of the classification
AND the description I give in the "label" field?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1391#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
