[QGIS-trac] Re: [Quantum GIS] #747: importing 3D geom into PostGIS
via SPIT plugin
Quantum GIS
qgis at qgis.org
Sat Jul 11 10:10:47 EDT 2009
#747: importing 3D geom into PostGIS via SPIT plugin
Reporter: pcavallini | Owner: nobody
Type: bug | Status: new
Priority: minor: annoyance or enhancement | Milestone: Version 1.2.0
Component: SPIT | Version: HEAD
Resolution: | Keywords: PostGIS 3D shapefiles
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Changes (by lutra):
* cc: pcav (added)
* milestone: Version 1.0.3 => Version 1.2.0
Comment:
I made a quick test with the data available here
http://download.gfoss.it/Merano/
and this is the result:
SPIT fails to export this 3d shapes to postgis with the following error
Problem inserting features from file:
/home/gio/Desktop/f05aa_UTM/f05aa_UTM.shp
The database gave an error while executing this SQL:
INSERT INTO "public"."f05aa_UTM" VALUES(0,'
51108','3','11','2003/09/06','10','1000','
405353','21051',NULL,NULL,NULL,NULL,' 0','0',... (rest of SQL
trimmed)
The error was:
ERROR: date/time field value out of range: "0000/00/00"
HINT: Perhaps you need a different "datestyle" setting.
Postgis Manager is able to export to Postgis without errors just one one
of these four shapfiles.
With the other three the error that is returned is
geometry contains non-closed rings
Beside this error, two layers do appear in postgis (but with missing
features).
All the three layers that are imported totally or partially in Postgis can
be visualized by qgis.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/747#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
