[QGIS-trac] Re: [Quantum GIS] #1753: QGis crashes in a Zoom to Full
Extent after an 'on the fly' transformation
Quantum GIS
qgis at qgis.org
Mon Jul 13 06:04:44 EDT 2009
#1753: QGis crashes in a Zoom to Full Extent after an 'on the fly' transformation
Reporter: gcarrillo | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.2.0
Component: Projection Support | Version: HEAD
Resolution: | Keywords: Raster Layer Transformation On The Fly SRC
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Comment (by pcav):
Tested, I cannot make QGIS crash with test.tif, following the same steps.
This with self-compiled QGIS from today's trunk, libgdal 1.5.4 on Debian
testing, up to date.
I get some warning, however:
Warning: QgsCoordinateReferenceSystem::getRecord failed : select * from
tbl_srs where parameters='+proj=tmerc +lat_0=4.599047222222223
+lon_0=-77.08091666666667 +k=1 +x_0=1000000 +y_0=1000000 +ellps=intl
+units=m +no_defs'
Warning: QgsCoordinateReferenceSystem::findMatchingProj will only work if
prj acr ellipsoid acr and proj4string are set!...
+units=m +no_defs'
Warning: Object::connect: No such signal QgsRasterLayer::editingStarted()
in
/home_slides/Desktop/build/qgis_unstable/src/app/legend/qgslegend.cpp:548
Warning: Object::connect: No such signal QgsRasterLayer::editingStopped()
in
/home_slides/Desktop/build/qgis_unstable/src/app/legend/qgslegend.cpp:549
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1753#comment:13>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
